This package has been deprecated
Author message:
This package is archived and no longer maintained. For support, visit https://github.com/expressjs/express/discussions
connect-multiparty
2.2.0 • Public • Published
connect-multiparty
NPM Version NPM Downloads Build Status Test Coverage
connect middleware for multiparty.
I actually recommend against using this module. It's cleaner to use the multiparty API directly.
This middleware will create temp files on your server and never clean them up. Thus you should not add this middleware to all routes; only to the ones in which you want to accept uploads. And in these endpoints, be sure to delete all temp files, even the ones that you don't use.
Usage
var multipart = require('connect-multiparty');
var multipartMiddleware = multipart();
app.post('/upload', multipartMiddleware, function(req, resp) {
  console.log(req.body, req.files);
  // don't forget to delete all req.files when done
If you pass options to multipart(), they are passed directly into multiparty.
MIT
Readme
Keywords
none
Package Sidebar
Install
npm i connect-multiparty
Weekly Downloads
75,790
Version
2.2.0
MIT
Unpacked Size
8.69 kB
Total Files
5
Last publish
Collaborators
  • dougwilson
  • superjoe
  • ulisesgascon
